Overview Features Reviews
NEW
2018 Edition KICKR Smart Trainer
£999.99
More Views
NEW
The ultimate indoor bike trainer experience
SKU# WFBKTR118
£999.99
  • Free Shipping On Orders Over £54.99
  • 30 Day, No Hassle Returns
  • 2 Year Limited Warranty
Reviews
Product Overview
Building on the proven success of Wahoo’s line of KICKR Smart Trainers, the new 2018 edition delivers a virtually silent experience and a specially engineered, heavier flywheel to provide cyclists with the exact inertia they need to recreate the feeling of riding outdoors. The KICKR continues to provide the best in class indoor smart trainer design with carbon steel body for the durability. Its unmatched compatibility expands to include our new indoor grade simulator, the Wahoo KICKR CLIMB, and our new Bluetooth and ANT+ powered fan, the KICKR HEADWIND. The KICKR includes an 11 speed cassette for easy setup and an RPM cadence sensor.
NOTE: The KICKR only ships to select countries. Signature required for delivery of all KICKR shipments.
NEW! Virtually Silent Operation
The KICKR's new design offers an ultra quiet riding experience.
NEW! Optimized Flywheel
KICKR's new larger and heavier flywheel was specially engineered to provide riders with a more precise inertia needed to recreate an outdoor ride feel while training indoors.
KICKR CLIMB Compatible
Wahoo's KICKR CLIMB indoor grade simulator was designed in conjunction with the KICKR smart trainers to deliver a unmatched indoor training experience when combined.
KICKR HEADWIND Compatible
KICKR HEADWIND was designed to deliver innovative climate control to your indoor training experience.
Thru Axle Compatible
The new KICKR features 12x142 and 12x148 thru axle compatibility in addition to standard 130/135mm quick release. Click to find out if your bike is compatible.
Disc Brake Clearance
An update to the main mast ensures clearance for flat mount and disk brake equipped bikes.
+/- 2% Power Accuracy
Enhanced power accuracy to provide accurate power measurement and generate up to 2200W.
20% Maximum Grade
Maximum percent grade adjusts to simulate up to a 20 degree incline.
LED Indicator Lights
Visual confirmation that KICKR is powered, connected and transmitting via Bluetooth and / or ANT+
ANT+, ANT+ FE-C and Bluetooth Connectivity
ANT+ and Bluetooth capabilities allow it to connect to both smartphones and GPS devices simultaneously or separately. An ANT+ FE-C connection allows the KICKR to be controlled from any FE-C enabled device or application.
Professional Grade Durability
Controlled resistance
When connected to your device, it automatically sets your resistance via your favorite app or software
Realistic ride feel
The KICKR flywheel is innovative and proven technology emulates the power and inertia experienced during outdoor riding. It provides the most realistic ride feel especially when using virtual riding/training platforms like Zwift and Trainer Road.
Measures speed, distance, power, and cadence
Get all your vital cycling metrics on your indoor ride. Cadence only available when paired with a Wahoo RPM Cadence Sensor that is included.
Third Party App Compatibility
Works with popular training apps such as Zwift and TrainerRoad. For more details on which apps are compatible with the KICKR, download our in-depth KICKR app comparison chart.
Compatible with a third party power meter.
BONUS FEATURE! Free Trials from our favorite App partners
Click here for KICKR instructions
Specs
Part Number: WFBKTR118
KICKR Version: 4
Dimensions (legs open): 20"L x 28"W x 17"H
Dimensions (legs closed): 20"L x 9"W x 17"H
Weight (unboxed): 47 lb
Rear Wheel Size: 24" RD / 24" MTB / 650c RD / 26" MTB / 700c RD / 650b MTB / 29" MTB
Hub Types: 130/135mm QR, 12x142, and 12x148 Thru Axle - Adapters included
Drivetrain:
  • Out of Box: 11 Speed Cassette with 11-28 ratio
  • Requires Purchase/Installation of New Cassette: 8/9/10 Speed SRAM/Shimano
KICKR CLIMB Compatible: Yes
KICKR HEADWIND Compatible: Yes
Cadence: RPM Cadence Sensor included
Front Wheel Block: Not needed
Resistance Type: Electromagnetic
Accuracy: + / - 2%
Wireless Software Updates: Yes
3rd Party Power Meter Support: Yes
Connectivity: ANT+, ANT+ FE-C, and Bluetooth
Devices: iOS, Android, PC (Mac and Windows)
Max User Weight: 250 lb
Power Requirements: 100-240V~1.5A 50-60 Hz
Flywheel Weight: 16 lb
Maximum Simulated Grade: 20%
Maximum Power Output: 2200W
2018 Edition KICKR Smart Trainer is rated 4.4 out of 5 by 120.
Rated 4 out of 5 by from Love Hate Relationship...mostly Love First unit developed a noticeable humming noise, not correctable by replacement of a small spline pin in the drive shaft. I coordinated customer service through my LBS; Wahoo customer service was amazing. Replaced my unit with a brand new unit, and no problems since. 4 stars because of the initial problem with the first unit. the 2018 Kickr is a great product, synch to Zwift every time.
Date published: 2019-01-14
Rated 4 out of 5 by from Some issues but good great support The combination of the KICKR 2018, KICKR Climb and Headwind linked to Zwift has made for a great experience and kept me riding in the poor weather. The addition of the Climb really added realism and made it a lot more fun, especially when using Zwift. The Headwind was expensive for what it is but I managed to get a good discount. It works very well and somehow seems to cool the air it pumps out. Despite the price I think it is a great device. I did have issues with the first unit which developed the dreaded clicking sound. The replacement unit came relatively quickly but had a slipping belt after a few rides. Managed to correct this with the help of Wahoo support by taking the belt from the old unit and mounting it on the new unit - an easy fix! Support in the UK does take a little longer due to the time difference with the US. But in all honesty they have been great and very helpful. A UK service centre would be nice but perhaps not enough volume to justify this. Perhaps a deal with a few good bike shops around the UK could be a possible solution? Most good bike shops have a workshop with capable mechanics. I sullied with parts and tools this would be mutually beneficial in my view. There do seem to be some manufacturing quality control issues but I am sure Wahoo will get on top of these. Despite the issues a great product.
Date published: 2019-01-03
Rated 2 out of 5 by from my kickr yeap bought it liked it for 3 weeks Than power cord went out waited 2 weeks got new one few weeks later stopped registered correctly thought i had that problem fixed, today couldnt get it to sinc up and work again another issue, every issue is send a email and wait no live person again, bought my wife a cyclops not one problem works every time and 300 bucks cheaper, so one unhappy customers for quality of machine, see what happens know ,
Date published: 2018-12-30
Rated 5 out of 5 by from Works well for my purpose I was using much louder Elite model before, and my bike shop recommended Wahoo Trainer + Climb combo. After switching, my family can fall a sleep without any disruption or vibration noise. Also, the Climb combination work great together with the Zwift map. The VR world is nothing compare to the real riding, but with cold weather and micro dust in the air, the indoor work out with these units are perfect for me in winter season.
Date published: 2018-12-23
Rated 5 out of 5 by from Awesome Smart Trainer I actually bought a Wahoo Snap at first and fell in love with what a riding on a Smart Trainer was going to be like. Unfortunately the Snap was to noisy for my daughter and wife who slept above my riding area. I returned the Snap and got a Kickr. The Kickr is not only quiet the accuracy and road like feel a leaps and bounds ahead of the Snap. I read some really concerning reviews and wondered if my unit would start to make loud clunking or worse yet grind to a halt. However, after 300 miles of riding on my Kickr it is still kicking and I love the experience and it has been a great alternative to road riding and being away from my family. The smart trainer has helped my balance my training with my family time which is a win/win.
Date published: 2018-12-18
Rated 1 out of 5 by from Excessive noise and vibration I bought this 2 months ago and could not be more disappointed. The product does not work as advertised. It's not quiet at all. It vibrates heavily and makes a loud rumble/droning noise, which makes the trainer unusable in an apartment building. My neighbors complained about it and said it was like somebody left a sander running on the floor and that it was causing his wall to shake. His words, not mine. I'm using the Wahoo trainer mat and have followed the instructions carefully even though they were not very easy to understand. What's even more upsetting is that this model is really expensive for it to be so defective.
Date published: 2018-12-12
Rated 1 out of 5 by from Worst instructions in history I have never seen any product of any type that has had worse instructions, or instructions that do not match what is actually shown when using the product. The power that it is showing is also not even close to the power being shown by my power meter. I did an initial spin down calibration but after seeing how different my power readings are versus reality I tried to do another calibration and none of the instructions are matching what is shown on my wahoo fitness app screen. And all of the modes that supposedly exist like urgh mode, at cetera, cannot be found when using their instructions.
Date published: 2018-12-09
Rated 5 out of 5 by from Really Great Trainer I am very pleased with my Kickr 2018. Had an earlier iteration of Kickr and was fairly well satisfied. The 2018 is so much better, though. It is smoother, quieter, more responsive, and is solid throughout my rides. If your're committed to indoor training and realize the time devoted to it, it is well worth it to upgrade to the 2018 model. I use the Kickr with Apple TV and Zwift and the two play really well together.
Date published: 2018-12-06
  • y_2019, m_1, d_18, h_24
  • bvseo_bulk, prod_bvrr, vn_bulk_2.0.9
  • cp_1, bvpage1
  • co_hasreviews, tv_3, tr_117
  • loc_en_US, sid_WFBKTR118, prod, sort_[SortEntry(order=FEATURED, direction=DESCENDING), SortEntry(order=SUBMISSION_TIME, direction=DESCENDING)]
  • clientName_wahoofitness
  • bvseo_sdk, p_sdk, 3.2.0
  • CLOUD, getContent, 40.15ms
Product Overview
20% Maximum Grade
Realistic ride feel
Specs
KICKR Version: 4
Drivetrain:
Accuracy: + / - 2%
Reviews
