Overview Features Reviews
Certified Reconditioned - 2014 Edition KICKR Turbo Trainer
Factory Certified Reconditioned 2014 Edition KICKR Smart Indoor Bike Trainer with full 2 year warranty.
Out of Stock
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 2.59ms
  • Free Economy Shipping
  • 30 Day, No Hassle Returns
  • 2 Year Limited Warranty
Product Overview
This is a refurbished Original Model (2014 Edition) KICKR that carries the full 1 year warranty. Our team of Wahooligans have completely tested the product and brought it up to factory specifications. Cosmetically, there might be
PLEASE NOTE: The KICKR only ships to select countries. Signature required for delivery of all KICKR shipments.
THIS MODEL KICKR IS NOT COMPATIBLE WITH KICKR CLIMB.
Dual Band Technology
Both ANT+ and BLE capabilities allow it to connect to both smartphones and GPS devices simultaneous or separately
Accurate Power with Built-In Power Meter
Wheel off design for direct, lab accurate power measurement at the hub that is consistent and calibrated throughout every grueling mile. Accurate to +/- 3%.
Controlled resistance
When connected to your device, it automatically sets your resistance via your favorite app or software
Realistic road feel
The KICKR flywheel is innovative and proven technology emulates the power and inertia experienced during outdoor riding. It provides the most realistic road feel especially when using virtual riding/training platforms like Zwift and Trainer Road.
Measures speed, distance, power, and cadence
Get all your vital cycling metrics on your indoor ride. Cadence only available when paired with a Wahoo RPM. 11 speed model includes an RPM and the 10 speed model does not.
Reduced Noise
Quiet as your favorite fluid trainer; no shouting required!
ANT+ FE-C Control
The KICKR now has ANT+ FE-C support, which allows the KICKR to be controlled from any FE-C enabled device or application, including products like Garmin bike computers.
Third Party App Compatibility
Works with popular training apps such as Zwift and TrainerRoad. For more details on which apps are compatible with the KICKR, download our in-depth KICKR app comparison chart.
Compatible with a third party power meter.
Click here for KICKR instructions
Specs
  • Weight: 47 lbs
  • Max User Weight: 250 lbs
  • Flywheel Weight: 12 lbs
  • Belt Type: Gates Carbon Drive
  • Wireless technology: Bluetooth 4.0 and ANT+
  • Metrics: Speed, distance, power, and cadence (with a Wahoo RPM)
  • Maximum Simulated Grade: 15% (assumed rider/bike weight of 175 lbs)
  • Maximum Power Output: 1900 Watts (at 25 mph)
  • Noise Level: 70 dB (measured at 3ft while riding 250 Watts at 10 mph)
  • Footprint with legs open: 21" x 28" (54 cm x 71 cm)
  • Footprint with legs collapsed: 21" x 9" (54 cm x 23 cm)
  • Hub Types: 130mm and 135mm Quick Release and 12x142 Thru-Axle with adapter (sold separately)
  • Rear Wheel Size: 24" RD / 24" MTB / 650c RD / 26" MTB / 700c RD / 650b MTB / 29" MTB
  • Drivetrain:
    • Out of Box (11 speed model): SRAM/Shimano 11-speed ready, cassette already installed. Campagnolo 9/10/11-speed with Campagnolo freehub adapter (sold separately)
    • Out of Box (10 speed model): SRAM/Shimano 10-speed ready, cassette already installed. 10 speed model is also compatible with 11speed drivetrains with purchase/Installation of New Cassette for use with SRAM/Shimano 7/8/9 or 11-speed drivetrains. Campagnolo 9/10/11-speed (also requires Campagnolo freehub adapter - sold separately)
    • Note for Campagnolo 11-speed Compatibility: Rear derailleur may contact a plastic cover when shifting into the largest cog on the cassette; this may prevent the use of that cog.
  • THIS MODEL IS NOT COMPATIBLE WITH KICKR CLIMB.
  • CLOUD, getReviews, 2.07ms
Product Overview
Realistic road feel
Reduced Noise
ANT+ FE-C Control
For more info, see Faq
Specs
  • Weight: 47 lbs
  • Drivetrain:
Reviews
