Overview Features Reviews
Certified Reconditioned - 2015 Edition KICKR SNAP Bike Trainer
£299.99
Factory Certified Refurbished 2015 Edition KICKR SNAP with full 2 year warranty.
Out of Stock
  • bvseo_sdk, p_sdk, 3.2.1
  • CLOUD, getAggregateRating, 53.31ms
£299.99
  • Free Economy Shipping
  • 30 Day, No Hassle Returns
  • 2 Year Limited Warranty
Product Overview
This is a refurbished original model KICKR SNAP that carries the full 2 year warranty. Our team of Wahooligans have completely tested the product and brought it up to factory specifications. Cosmetically, there might be some scratches or nicks.
PLEASE NOTE: The KICKR SNAP only ships to select countries. Signature required for delivery of all KICKR SNAP shipments.
THIS MODEL KICKR SNAP IS NOT COMPATIBLE WITH KICKR CLIMB.
Dual Band Technology
Both ANT+ and Bluetooth Smart capabilities allow it to connect to both smartphones and GPS devices simultaneous or separately
Convenient Design
SNAP's wheel-on design makes it easy to turn your regular road or mountain bike into a powerful indoor smart trainer.
Super Stability
Made from high strength carbon steel and featuring a wide stance, SNAP is designed to keep its feet firmly planted on the floor and your bike securely locked in so you can train with confidence.
Reliable power measurement
Designed for consistent power measurement so that you can monitor and adjust your intensity. Accurate to +/- 5%.
Controlled resistance
When connected to your device, it automatically sets your resistance via your favorite app or software
Realistic road feel
The SNAP flywheel is innovative and proven technology emulates the power and inertia experienced during outdoor riding. It provides the most realistic road feel especially when using virtual riding/training platforms like Zwift and Trainer Road.
Measures speed, distance, and power.
Get vital cycling metrics on your indoor ride.
Reduced Noise
Super quiet; no shouting required!
ANT+ FE-C Control
The SNAP now has ANT+ FE-C support, which allows the SNAP to be controlled from any FE-C enabled device or application, including products like Garmin bike computers.
Third Party App Compatibility
Works with popular training apps such as Zwift and TrainerRoad. For more details on which apps are compatible with the KICKR, download our in-depth KICKR app comparison chart.
Click here for KICKR SNAP instructions
Specs
  • Part Number: WFREFSNAP
  • Dimensions (legs open):29"" x 26"" (74cm x 66cm)
  • Weight: 38lbs
  • Rear Wheel size: 650c RD / 26"" MTB / 700c RD / 650b MTB / 29"" MTB
    Hub Types: 130mm and 135mm Quick Release and 142x12 Thru-Axle with adapter (sold separately)
  • Drivetrain: N/A
  • Metrics: Speed, power, distance
  • Front wheel block: Included
    Resistance type: Electromagnetic
  • Accuracy: +/- 5%
  • Wireless software updates: Yes
  • 3rd party power meter support: No
  • Connectivity: ANT+, ANT+ FE-C, and Bluetooth Smart
  • Devices: iOS / Android / PC (Mac and Windows)
  • Max User Weight: 250 lbs
  • Flywheel Weight: 10.5 lbs
  • Maximum Simulated Grade: 12%
  • Maximum Power Output: 1500 Watts
  • THIS MODEL KICKR SNAP IS NOT COMPATIBLE WITH KICKR CLIMB.
  • CLOUD, getReviews, 3.31ms
Product Overview
Convenient Design
Super Stability
Realistic road feel
Reduced Noise
ANT+ FE-C Control
For more info, see Faq
Specs
  • Weight: 38lbs
  • Drivetrain: N/A
  • Accuracy: +/- 5%
Reviews
