EASY ACTION SPRING |
The Easy Tension walkable bike cleat utilizes an easy action spring mechanism for a simpler pedal engagement experience for those smaller or more novice riders. |
ENHANCED WALKABILITY |
The dimpled, low profile design and rubberized texture allow for better traction and enhanced walkability. |
3 AXIS ADJUSTABILITY |
Independent 3 axis adjustability to optimize fit and enhance performance through better biomechanics on the bike. |
IDEAL FORE & AFT PLACEMENT |
Up to 14mm of fore/aft (forward & back movement) adjustability to lock the cleat base plate into place on the bottom side of the shoe. |
PRECISE SIDE TO SIDE TUNING |
With the left/right adjustment you can further dial in your cleat placement. The cleat spring housing plat allows for up to 8mm of side to side flexibility. |
ROTATIONAL FREE FLOAT |
1 - 15 degrees of micro-adjustable free float to dial in the perfect amount of movement. |
SPRING TECHNOLOGY |
The SPEEDPLAY Easy Tension cleat utilizes spring technology to allow for an easy and effective clipless experience. |
Step, snap, and ride with confidence using the SPEEDPLAY easy tension walkable road cleat. While retaining all the advantages of the SPEEDPLAY Bike Pedal System, the easy action spring mechanism makes it a breeze to clip in and out. Enhanced walkability and adjustability make this bike cleat comfortable and functional for every level of cyclist.
