Cycling Sensors
Wahoo cycling sensors
Small sensors, better data, safer rides. The TRACKR RADAR watches the road behind you and doubles as a smart tail light. The TRACKR SPEED straps around your wheel hub and allows you to record exact speed and distance with a computer or phone app, no GPS needed. Both run dual band ANT+ and Bluetooth, and both feed the same Wahoo ecosystem as your bike computer and trainer. This guide covers each sensor: how they compare, full specifications and the questions riders ask most.
Wahoo TRACKR RADAR bike radar and tail light
Radar + Tail Light
TRACKR RADAR
See what's coming up behind you
£179.99
An all-in-one tail light and radar that keeps you aware, visible, and in control. It spots vehicles up to 150 meters (164 yards) back and warns you on your bike computer before you hear them.
The TRACKR RADAR bike radar and tail light pairs with ELEMNT GPS bike computers and other compatible head units and watches over ANT+ and Bluetooth. Approaching cars appear as vehicle icons on your screen with audible and visual alerts, that change color based on the speed of the approaching vehicle. Dual high-intensity LEDs adjust to traffic, an accelerometer-driven Brake Light brightens as you slow, a Quick Alert Light flashes when a vehicle closes in, and Battery Saver dims the light when the road behind is clear. Wahoo walks through the moments when radar detection on a bike prevents crashes if you want the case for riding with one.
  • 150m (164yd) Detection Range
  • 53 Max Lumens
  • 20hr Max Battery
  • IPX7 Water Rating
  • 99g Weight
  • Vehicle detection to 150 meters (164 yards)
    The radar tracks vehicles approaching from behind up to 150 meters away and pushes audible and on-screen alerts to your paired bike computer or watch.
  • Smart tail light
    Dual high-intensity LEDs run steady or flashing up to 53 lumens. The light responds to approaching traffic, and a brake feature brightens it when you slow down.
  • Smart light control
    ELEMNT bike computers manage the light hands free. The radar runs a Brake Light that brightens as you slow, a Quick Alert Light that flashes when traffic closes in, and a Battery Saver that drops the brightness when no vehicles are around, stretching runtime to 20 hours.
  • Quarter-turn mount
    A quick-connect strap and quarter-turn mount with three wedge options fits round, aero, D-shaped, and flat seatposts.
Wahoo TRACKR SPEED magnet-less bike speed sensor
Speed Sensor
TRACKR SPEED
Exact speed and distance, no GPS needed
£29.99
A magnet-less speed sensor that mounts to your wheel hub and records precise speed and distance. It works on the trainer, in the city, and anywhere GPS drops out.
The TRACKR SPEED bike speed sensor attaches to most wheel hubs up to 40mm in diameter and broadcasts over ANT+ and Bluetooth at the same time. A replaceable CR2032 coin cell runs for up to 200 hours of riding. Two LEDs confirm connection and speed detection at a glance. It works with ELEMNT bike computers and third-party cycling apps alike, though it is not compatible with most spin bikes.
  • 200hr Battery Life
  • 13g Weight
  • BT+ANT+ Dual Band
  • IPX7 Water Rating
  • 40mm Max Hub Size
  • Magnet-less hub mount
    No magnets or spoke alignment. The sensor straps to the wheel hub and reads wheel rotation directly, on almost any bike.
  • Dual band broadcasting
    ANT+ and Bluetooth run at the same time. Pair it with your bike computer, watch, phone, and indoor apps together.
  • 200-hour replaceable battery
    A standard CR2032 coin cell lasts up to 200 riding hours. Swap it in seconds. There is nothing to charge.
  • LED status lights
    A blue LED shows the device connection and a red LED confirms speed detection before you roll out.
Which sensor does what
Two sensors, two jobs: awareness of the road behind you, and exact speed and distance.
Feature comparison between TRACKR RADAR and TRACKR SPEED
Feature TRACKR RADAR TRACKR SPEED
What it measures Traffic behind you Speed and distance
Mounts to Seatpost Wheel hub
Price £179.99 £29.99
Battery Rechargeable, 10 to 20 hrs CR2032, up to 200 hrs
Connectivity ANT+, Bluetooth 3x ANT+, Bluetooth 1x
Extras 53-lumen tail light, brake light Works where GPS fails
Water resistance IPX7 IPX7
Best for Road riders in traffic Accurate data on any ride
Learn more Bike radar and tail light Bike speed sensor
Technical specifications
The full detail on both sensors, side by side.
Detailed list of technical specifications for TRACKR RADAR and TRACKR SPEED
Specification TRACKR RADAR TRACKR SPEED
Detection / sensing Radar, 150m behind Wheel rotation, magnet-less
Light output 10 to 53 lumens, 4 modes None
Battery Rechargeable CR2032 coin cell
Battery life 10 to 20 hrs by mode Up to 200 hrs
Connectivity ANT+, ANT+ Smart Light, Bluetooth 3x ANT+, Bluetooth 1x
Mounting Quarter-turn, 3 wedges Hub strap, up to 40mm
Weight 99g 13g
Status indicator LED Blue + red LEDs
One app, every sensor
Pair either sensor with the free Wahoo app to set it up, update firmware, and record your rides.
  • Guided pairing
    The app finds your sensor over Bluetooth and walks through setup in a couple of minutes.
  • Firmware updates
    Radar and sensor firmware stays current over the air, straight from your phone.
  • Light settings
    Pick the TRACKR RADAR's custom light settings in the Wahoo app, change the Light Mode on the device, or let an ELEMNT computer manage them on the road.
  • Ride recording
    Record speed and distance in the app when you ride without a bike computer.
  • Third-party sync
    Finished rides go to Strava, TrainingPeaks, Apple Health, Komoot, and over 110 other apps.
  • Works beyond Wahoo
    Dual band ANT+ and Bluetooth pairs these sensors with most head units, watches, and indoor apps, Wahoo or not.
What you need to know
The most common questions about Wahoo cycling sensors.
Do I need a Wahoo bike computer to use these sensors?
How does the TRACKR RADAR alert me to traffic?
Why buy a speed sensor when GPS tracks my speed?
What batteries do the sensors use?
Can I use these sensors in the rain?
Will they work with Zwift and other indoor apps?
