KICKR Smart Trainer
Choose your version
£774.99
  • Maximum Power Output: 2200W
  • 20% Simulated Incline
  • View More
  • +/- 1% power accuracy
  • Side-to-side movement
  • Virtually silent operation
  • View More
Complete Your Setup
KICKR only
Total £774.99
Fitness2021
Bicycling2020
Bestintest
Di Award
KICKR Benefits
KICKR Smart Trainer
Optimized Flywheel Technology
Ready to Ride
Auto Calibration
Side-to-side Movement
Take your ride to new heights
Max Grade Simulation
10%
12%
16%
20%
Min Grade Simulation
-10%
-12%
-15%
-20%
Max Power (Watts)
1000w
1500w
1800w
2200w
KICKR Smart Trainer
KICKR Smart Trainer
KICKR Features
Realistic Ride Feel
Controlled Resistance
KICKR AXIS Feet
Professional Grade Durability
Seamless Connectivity
Connectivity
WiFi
Bluetooth Up to 3 Connections
ANT plus ANT+, ANT+ FE-C
2200 Watt
Max Power Output
Accuracy +/- 1% Power
Accuracy
20%
Maximum Incline
-10%
Maximum Decline
Belt Drive
Drivetrain
2200 Watts
Maximum Simulated Grade
20%
Minimum Simulated Grade
-10%
Product Weight
47 lb / 22 kg
Drivetrain
Belt Drive
Resistance Type
Electromagnetic
Power Accuracy
+/-1%
Connectivity
Cassette
Hub Types
Adapters
Maximum Rider Weight
250 lb / 113 kg
What’s in the Box
  • Refurbished KICKR
  • KICKR
  • AC Power Adapter
  • Quick Release Skewer
  • 1.8mm Cassette Spacer
  • Disc Brake Caliper Spacer
Supported Devices
Bike Compatibility
Start
Compare smart trainers
£774.99
Accuracy
Accuracy +/- 1%
Wireless Firmware Updates
Max Power Wattage 2200 Watts
Simulated Gradient
Zwift Cog & Click
Zwift Cog & Click Compatible
KICKR CLIMB Compatible
ERG Easy Ramp ERG Easy Ramp
RaceMode
RaceMode
KICKR Core 2
KICKR CORE 2
£499.99
Accuracy
Accuracy +/- 2%
Max Power Wattage 1800 Watts
Simulated Gradient
Zwift Cog & Click
RaceMode
RaceMode
£549.99
Accuracy
*onboard power available
Max Power Wattage 1500 Watts
Simulated Gradient
4 items
Smart Trainer
