SPEEDPLAY ZERO Stainless Steel Pedals
£179.99
Built to take on anything, the SPEEDPLAY ZERO road pedal is uniquely qualified to withstand the demands of everything from all-out racing to the epic grind of a double-century. The stainless steel dual-sided bike pedal and integrated cleat system offer peak power transfer and exceptional durability. The customized fit and dual-sided entry will allow you to crank on the pedals in confidence and comfort.
  • Weight: 222 g per pair
  • Q Factor: 53 mm
  • Cornering Clearance: 39°
  • Integrated profile keeps the pedal body compact and clean
  • Standard Tension cleats included, with a walkable cleat adaptor
Complete Your Setup
Add accessories, ships with your SPEEDPLAY ZERO
SPEEDPLAY ZERO only
Total £179.99
SPEEDPLAY ZERO Features
Dual-Sided Entry
SPEEDPLAY ZERO pedals' symmetrical design allows for effortless dual-sided entry. No more fumbling—clip in quickly and ride off with confidence.
Cyclist clipping road shoe into the symmetrical, dual-sided Speedplay Zero pedal
Enhanced Walkability
Integrated Profile
ZERO pedals and Standard Tension Cleat create a streamlined, secure connection, improving power transfer and aerodynamics.
Unbeatable Stack Height
Close-up highlighting the minimal distance and material between the shoe sole and the stainless steel pedal spindle
3-Axis Cleat Adjustability
Optimized Biomechanics
Rotational Free Float
Superior Cornering Clearance
Exceptional Durability
Stainless steel build and sealed bearings offer long-lasting durability with minimal maintenance for even the most demanding cyclists.
Detailed view of the premium Grivory body and stainless steel spindle
ZERO pedals include a set of Standard Tension Cleats and cleat surrounds for an aerodynamic and walkable system.
Easy Tension Cleat Compatible
What’s Included
  • Left and Right Pedals
  • Cleat Assembly
  • Screw Packet
  • Quick Start Guide
Tech Specs
  • Part Number: WFPRA1S53
  • Shipping Weight: 1.18lb
  • Country of Origin: Vietnam
  • Weight: 224g per pair
  • Q Factor: 53mm
  • Body Material: Grivory
  • Cornering Clearance: 37°
Compare Speedplay pedals
SPEEDPLAY NANO bike pedals
SPEEDPLAY NANO
£379.99
  • Weight: 168g per pair
  • Spindle Material: Titanium
  • Q Factor: 53mm
SPEEDPLAY ZERO bike pedals
SPEEDPLAY ZERO
£179.99
  • Weight: 222g per pair
  • Q Factor: 53mm
SPEEDPLAY COMP bike pedals
SPEEDPLAY COMP
£99.99
  • Weight: 232g per pair
  • Spindle Material: Chromoly
SPEEDPLAY AERO bike pedals
SPEEDPLAY AERO
£239.99
  • Q Factor: 53mm
SPEEDPLAY ZERO
