£1,799.99
  • Power Accuracy: +/- 1%
  • Maximum Power Output: 2200W
  • Virtually silent operation
Complete Your Setup
Add accessories, ships with your KICKR BIKE SHIFT
KICKR BIKE SHIFT only
Total £1,799.99
KICKR BIKE SHIFT Features
KICKR BIKE SHIFT Smart Bike
Real-time Response
KICKR BIKE SHIFT’s brake and belt drivetrain system delivers responsive resistance to grade and power changes.
Reality Shift
Virtual shifting and custom gearing let you match the gear ratios of your outdoor bike, replicating the major groupsets from Shimano, SRAM and Campagnolo.
True Fit
Guided by an intuitive set-up app, KICKR BIKE SHIFT’s 5-point adjustment system lets you dial in frame, setback and reach for comfort and performance.
Your ride. Inside.
Max Grade Simulation
10%
12%
16%
20%
Min Grade Simulation
-10%
-12%
-15%
-20%
Max Power (Watts)
1000w
1500w
1800w
2200w
Real-Time Response
KICKR BIKE SHIFT’s innovative brake and belt drivetrain system delivers lightning fast resistance response to grade and power changes.
Five Points of Adjustable Fit
Adjust the fit of your smart bike to match your outdoor bike’s geometry across 5 points — stack, reach, setback, saddle height, and frame height.
Programmable Virtual Shifting
Customize the KICKR BIKE SHIFT controls to match shifters from the leading manufacturers — SRAM, Shimano, and Campagnolo.
Programmable Gearing
Connectivity
WiFi
Bluetooth
ANT plus ANT+, ANT+ FE-C
2200 Watt
Max Power Output
Accuracy +/- 1% Power
Accuracy
20%
Maximum Incline
-15%
Maximum Decline
Belt Drive
Drivetrain
2200 Watts
Maximum Simulated Grade
20%
Minimum Simulated Grade
-15%
Product Weight
79 lb / 36 kg
Drivetrain
Belt Drive
Resistance Type
Electronic Brake
Power Accuracy
+/-1%
Connectivity
Crank Arm Lengths
165mm, 167.5mm, 170mm, 172.5mm, and 175mm
Rider Height Range
5 feet (152 cm) to 6 feet 4 inches (193 cm)
Maximum Rider Weight
250 lb / 113 kg
What’s in the Box
  • KICKR BIKE SHIFT smart bike
  • AC Power Adapter
  • Handlebar Assembly
  • Does not include pedals
Supported Devices
  • MacOS: WiFi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
  • Windows PC: WiFi or Direct Connect on the network, Bluetooth enabled or ANT+ dongle
KICKR BIKE SHIFT seatpost height adjustment detail
Your KICKR ride companion
Compare smart bikes
Wahoo KICKR BIKE PRO
KICKR BIKE PRO
£3,499.99
Wahoo App icon Compatible with Wahoo App
Wi-Fi, Bluetooth, and ANT+
Max Power Wattage 2500 Watts
93 lb
Wahoo KICKR BIKE SHIFT
Max Power Wattage 2200 Watts
79 lb
Spares & compatible add-ons for the KICKR BIKE SHIFT.
2 items
KICKR BIKE SHIFT
Indoor Bike Trainer
