KICKR BIKE PRO Smart Bike
£2,799.99 £3,499.99
KICKR BIKE PRO redefines indoor cycling. With next-gen shifter controls, premium touchpoints, and unmatched ride realism, it delivers the most immersive indoor training experience yet. Built for riders who demand peak performance and complete control, this is the evolution of indoor riding.
New Features
  • Power Accuracy: +/- 1%
  • Maximum Power Output: 2500W
  • Dimensions: 60 x 30 x 46 in / 153 x 76 x 117 cm
  • Rider Height Range: 5'0" (152 cm) to 6'4" (193 cm)
  • Built-in grade simulation tilts the bike up to 20% uphill and 15% down
  • Virtual shifting with custom gearing that replicates Shimano, SRAM and Campagnolo groupsets
  • Five-point adjustment guided by the Wahoo app matches your outdoor bike fit
  • Fi'zi:k Aliante R5 saddle, Solocush bar tape and a redesigned ergonomic handlebar
  • Virtually silent operation, always ready to ride
  • Simple assembly required - handlebar and seatpost assemblies attach with the included 4 mm and 5 mm Allen wrenches
  • Crank arm lengths: 165, 167.5, 170, 172.5 and 175 mm
  • Pedals not included
  • Fit setup is guided step by step in the Wahoo app
Complete your setup
Add accessories, ships with your KICKR BIKE PRO
KICKR BIKE PRO only
Total £2,799.99
KICKR BIKE PRO
KICKR BIKE Pro
Unmatched Ride Feel
Reality Shift
True Fit
Premium Touchpoints
KICKR BIKE Pro Ride Real
Ride Real
Max Grade Simulation
10%
12%
15%
20%
Min Grade Simulation
-10%
-12%
-15%
-20%
Max Power (Watts)
1500w
1800w
2200w
2500w
KICKR BIKE PRO Features
Legendary Ride Realism
Physical Grade Changes
Intuitive Control System
Premium Saddle
Premium Saddle
Ergonomic Bars
Ergonomic Bars
Programmable Virtual Shifting
Programmable Gearing
Adjustable Fit
Adjustable Fit
Multi-Sensor Simplicity
Seamless Connectivity
KICKR Race Mode
KICKR Race Mode
Wahoo Ecosystem
Wahoo Ecosystem
Connectivity
WiFi
Bluetooth
Direct Connect
ANT plus ANT+, ANT+ FE-C
2500 Watt
Max Power Output
Accuracy +/- 1% Power
Accuracy
20%
Maximum Incline
-15%
Maximum Decline
Electromagnetic and Enhanced Motor Electromagnetic & Enhanced Motor
Belt Drive
Drivetrain
Dimensions
60×30×46” / 153×76×117 cm [LxWxH]
Rider Height Range
5’ (152 cm) to 6’4” inches (193 cm)
Maximum Rider Weight
250 lb / 113 kg
Crank Arm Lengths
165 mm, 167.5 mm, 170 mm, 172.5 mm, and 175 mm
What’s in the Box
  • KICKR BIKE PRO Smart Bike
  • AC Power Adapter
  • Handlebar Assembly
  • Does not include pedals
Supported Devices
Your KICKR ride companion
How KICKR BIKE PRO compares to the bikes and trainers around it, what Race Mode does, and how the fit adjusts to you.
What's the difference between KICKR BIKE and the new KICKR BIKE PRO?
What is the Race Mode?
What's the benefit of the premium touch points on KICKR BIKE PRO?
What are the 5 customisable adjustments on KICKR BIKE PRO?
How does KICKR BIKE PRO differ from a traditional bike trainer?
Can aero bars be used with KICKR BIKE PRO?
The KICKR BIKE PRO stock handlebars are compatible with most aftermarket clip-on/bolt-on aerobars, offering a 31.8 mm diameter clamping surface that is 100 mm wide overall.  The stock stem clamp is 40 mm wide.  There is an available clamping surface from 20-50mm from the handlebar's center point on both sides.
Compare smart bikes
Wahoo KICKR BIKE PRO
KICKR BIKE PRO
£2,799.99 £3,499.99
Wi-Fi, Bluetooth, and ANT+
Max Power Wattage 2500 Watts
93 lb
Wahoo KICKR BIKE SHIFT
Max Power Wattage 2200 Watts
79 lb
Spares & compatible add-ons for the KICKR BIKE PRO.
2 items
KICKR BIKE PRO
Smart Bike
