Choose your version
Dual-Sided Current version
Single-Sided View this version
£679.99
The combined forces of Wahoo's proven power algorithms and SPEEDPLAY’s advanced features set SPEEDPLAY POWER power pedals a cut above the competition. By capturing total power, left-right balance and cadence, SPEEDPLAY POWER DUAL delivers all the actionable data required to generate performance improvements. Pair with the full Wahoo Ecosystem of smart devices to track, analyze and share your breakthrough gains.
Complete your setup
Add accessories, ships with your SPEEDPLAY POWER Dual-Sided Power Pedals
SPEEDPLAY POWER Dual-Sided Power Pedals only
Total £679.99
Dia22
SPEEDPLAY POWER Features
+/- 1% Power Accuracy
Lab tested accuracy that provides a precise power measurement for all training efforts.
Cyclist riding on a road showcasing the precision power measurement of the pedals
Dual-Sided Power Metrics
Track, analyze and improve your performance with SPEEDPLAY POWER's dual-sided power metrics: total power, cadence and left/right balance. This sports-science approach not only monitors power output but also provides insight to optimize pedal symmetry for a more efficient stroke.
Exploded view of the left and right Speedplay Power pedals highlighting the dual-sided sensors
Total Power
Whether crushing watts on the road or trainer, SPEEDPLAY POWER's left and right sensors deliver total power, giving the most accurate representation of your overall output.
Cyclist generating maximum watts, emphasizing total power output
Left/Right Balance
Dual-sided sensors provide left and right power percentage data, giving insight into power distribution. Ideal for injury recovery or improving pedal stroke efficiency.
Biomechanical diagram displaying independent left and right pedal stroke balance
Cadence
With its internal gyroscope, SPEEDPLAY POWER reports cadence data to help you identify your sweet spot effort and optimize power output.
Diagram showing the circular motion of the pedal stroke tracked by the internal gyroscope
Easy App Set-Up
The Wahoo Fitness app offers guided instructions to install SPEEDPLAY POWER on any bike, calibrate the pedals for accuracy, and perform firmware updates.
Smartphone displaying the Wahoo Fitness app setup process for Speedplay Power
Wahoo Ecosystem Compatible
Pair SPEEDPLAY POWER pedals with the Wahoo Ecosystem. Track metrics outdoors on an ELEMNT GPS Device or indoors on a KICKR Smart Trainer for consistent data anytime, anywhere.
Cyclist using a Wahoo KICKR smart trainer indoors, connected to the Wahoo ecosystem
Dual-Band ANT+ and Bluetooth Technology
SPEEDPLAY POWER can simultaneously connect to three Bluetooth devices while broadcasting to unlimited ANT+ devices.
Wahoo ELEMNT bike computer displaying live power metrics connected via ANT+ and Bluetooth
Enhanced Walkability
The slim profile cleat with rubber texture provides enhanced stability when walking off the bike in your road shoes.
Cyclists walking comfortably off the bike using the rubberized walkable cleats
Integrated Profile
SPEEDPLAY POWER and the SPEEDPLAY Standard Tension Cleat create a secure, streamlined connection that aids power transfer and aerodynamics.
Side profile view showing seamless aerodynamic integration between the power pedal and the cleat
Rotational Free Float
Top-down perspective of a cycling shoe pivoting to demonstrate 15 degrees of float
Easy Tension Cleat Compatible
Close-up of the optionally compatible Easy Tension Cleat system
What’s Included
  • Left and Right Power Pedals
  • Standard Tension Cleats
  • Washer (x2)
  • Cleat Assembly
  • Cleat Spacer
  • Screw Packet
  • Charging Cable and Clips
  • Quick Start Guide
Additional Tools Required for Assembly: #1 and #2 Philips Head Screwdriver and 8mm Allen Wrench
Tech Specs
  • Physical Dimensions: 9 x 4cm
  • Country Of Origin: Vietnam
  • Weight: 276g per pair
  • Stack Height: 13mm (3 hole)
  • Q Factor: 55mm
  • Body Material: Grivory
  • Cornering Clearance: 39°
  • Cleats: Standard Tension Included (Easy Tension Compatible)
  • Cleat Left-Right Adjustability: Up to 6mm
  • Battery Life: Up to 75 hours
  • Connectivity: ANT+, Bluetooth
  • Max Rider Weight: 250lbs
Accuracy against other power meters, what the pedals pair with, clipping in, and charging and upkeep.
How accurate are the Speedplay Power pedals for serious training?
The Speedplay Power pedals provide lab-tested ±1% accuracy, delivering professional-level precision for training and racing. This ensures consistent, reliable power data across all efforts—whether intervals, endurance rides, or performance testing. With dual-sided sensors, they measure total output from both legs, giving a complete picture of your performance. The result is highly accurate, dependable data that helps you train smarter, track progress effectively, and maximize results. Built for cyclists who demand the highest standards, the Speedplay Power pedals combine advanced technology with trusted accuracy, making them an excellent choice for pushing performance to the next level.
Will the Speedplay Power pedals work with my existing bike computer and training apps?
The Speedplay Power pedals offer dual-band ANT+ and Bluetooth for seamless connectivity with virtually any device. They can link to three Bluetooth devices at once while broadcasting to unlimited ANT+ devices, ensuring maximum flexibility. This makes them compatible with popular bike computers like Wahoo ELEMNT, as well as smartphones, tablets, and leading training apps such as Zwift and TrainerRoad. While they integrate flawlessly within the Wahoo ecosystem, they’re not limited to Wahoo products, giving riders the freedom to train with their preferred setup. With broad compatibility and reliable connections, these pedals make training simple, versatile, and hassle-free.
Are the Speedplay Power pedals difficult to clip into compared to other pedal systems?
The Speedplay Power pedals feature dual-sided entry, letting you clip in from either side without flipping the pedal. This design removes the hassle of single-sided systems, making engagement quick and effortless—perfect for fast starts, stoplight accelerations, or race situations. Beyond convenience, the dual-sided entry improves efficiency by positioning your foot closer to the spindle, maximizing power transfer with every pedal stroke. The result is smoother engagement, greater confidence, and enhanced performance. With their intuitive design and optimized biomechanics, Speedplay Power pedals deliver both ease of use and professional-level efficiency for every ride.
How often will I need to charge the Speedplay Power pedals, and what about maintenance?
The Speedplay Power pedals deliver up to 75 hours of ride time from a rechargeable lithium battery, so most cyclists only need to charge every few weeks. Designed for longevity, they feature stainless steel construction and a triple-sealed bearing system that minimizes maintenance while ensuring lasting durability. With built-in temperature compensation, the pedals maintain precise accuracy across all weather conditions, eliminating the need for frequent recalibration. This combination of long battery life, rugged design, and consistent performance makes the Speedplay Power pedals a reliable, low-maintenance choice for cyclists who want to focus on training, not equipment upkeep.
What specific training insights can I get from the Speedplay Power pedals that I can't get from other power meters?
The Speedplay Power pedals feature dual-sided sensors that deliver complete cycling metrics, including total power, cadence, and left/right balance. The balance data is especially useful for spotting leg power imbalances, aiding injury recovery, refining pedal stroke efficiency, and boosting overall performance. With cadence tracked by an internal gyroscope, riders gain detailed insights into pedaling dynamics for identifying optimal power and efficiency zones. This sports-science approach goes beyond simple watt measurement, providing a deeper understanding of technique. By combining precision data with actionable insights, the Speedplay Power pedals help cyclists train smarter and improve performance more effectively.
