SPEEDPLAY POWER Single-Sided Power Pedals
Choose your version
Single-Sided Current version
Dual-Sided View this version
£479.99
Built on the cutting-edge SPEEDPLAY Pedal System, SPEEDPLAY POWER single-sided power pedal delivers reliably accurate power and cadence data in a race-proven pedal system. This powerful combination creates an unrivaled power pedal that helps cyclists optimize performance by providing the visibility, adjustability and efficiencies needed to break through to the next level. Pair with the Wahoo ecosystem of smart devices for a more full picture of your data and performance, and to track, analyze, share and improve.
Complete your setup
Add accessories, ships with your SPEEDPLAY POWER Single-Sided Power Pedals
SPEEDPLAY POWER Single-Sided Power Pedals only
Total £479.99
Dia22
SPEEDPLAY POWER Features
+/- 1% Power Accuracy
Lab tested accuracy that provides a precise power measurement for all training efforts.
Cyclist riding on a road showcasing the precision power measurement of the pedals
Left-Sided Power Metrics
Track, analyze and improve your performance with SPEEDPLAY POWER's reliable power metrics. The left-sided sensor measures power and cadence, doubling the value to calculate your total power output for a focused, sports-science approach to your training.
Exploded view of the Speedplay Power pedal highlighting the power sensor
Total Power
Whether crushing watts on the road or trainer, SPEEDPLAY POWER's left sensor calculates total power by doubling your left leg's output, giving an accurate representation of your overall effort.
Cyclist generating maximum watts, emphasizing total power output
Cadence
With its internal gyroscope, SPEEDPLAY POWER reports cadence data to help you identify your sweet spot effort and optimize power output.
Diagram showing the circular motion of the pedal stroke tracked by the internal gyroscope
Easy App Set-Up
The Wahoo Fitness app offers guided instructions to install SPEEDPLAY POWER on any bike, calibrate the pedals for accuracy, and perform firmware updates.
Smartphone displaying the Wahoo Fitness app setup process for Speedplay Power
Wahoo Ecosystem Compatible
Pair SPEEDPLAY POWER pedals with the Wahoo Ecosystem. Track metrics outdoors on an ELEMNT GPS Device or indoors on a KICKR Smart Trainer for consistent data anytime, anywhere.
Cyclist using a Wahoo KICKR smart trainer indoors, connected to the Wahoo ecosystem
Dual-Band ANT+ and Bluetooth Technology
SPEEDPLAY POWER can simultaneously connect to three Bluetooth devices while broadcasting to unlimited ANT+ devices.
Wahoo ELEMNT bike computer displaying live power metrics connected via ANT+ and Bluetooth
Enhanced Walkability
The slim profile cleat with rubber texture provides enhanced stability when walking off the bike in your road shoes.
Cyclists walking comfortably off the bike using the rubberized walkable cleats
Integrated Profile
SPEEDPLAY POWER and the SPEEDPLAY Standard Tension Cleat create a secure, streamlined connection that aids power transfer and aerodynamics.
Side profile view showing seamless aerodynamic integration between the power pedal and the cleat
Rotational Free Float
Top-down perspective of a cycling shoe pivoting to demonstrate 15 degrees of float
Easy Tension Cleat Compatible
Close-up of the optionally compatible Easy Tension Cleat system
What’s Included
  • Left Power Pedal
  • Right Speedplay Zero Pedal
  • Standard Tension Cleats
  • Washer (x2)
  • Cleat Assembly
  • Cleat Spacer
  • Screw Packet
  • Charging Cable and Clip
  • Quick Start Guide
Additional Tools Required for Assembly: #1 and #2 Philips Head Screwdriver and 8mm Allen Wrench
Tech Specs
  • Physical Dimensions: 9 x 4cm
  • Country Of Origin: Vietnam
  • Weight: 249g per pair
  • Stack Height: 13mm (3 hole)
  • Q Factor: 55mm
  • Body Material: Grivory
  • Cornering Clearance: 39°
  • Cleats: Standard Tension Included (Easy Tension Compatible)
  • Cleat Left-Right Adjustability: Up to 6mm
  • Battery Life: Up to 75 hours
  • Connectivity: ANT+, Bluetooth
  • Max Rider Weight: 250lbs
Accuracy against other power meters, what the pedals pair with, clipping in, and charging and upkeep.
How accurate are the Speedplay Power pedals for serious training?
The Speedplay Power pedals provide lab-tested ±1% accuracy, delivering professional-level precision for training and racing. This ensures consistent, reliable power data across all efforts—whether intervals, endurance rides, or performance testing. With a left-sided sensor, it accurately measures your left leg's output and doubles it to calculate your total power. The result is highly accurate, dependable data that helps you train smarter, track progress effectively, and maximize results. Built for cyclists who demand the highest standards, the Speedplay Power pedals combine advanced technology with trusted accuracy, making them an excellent choice for pushing performance to the next level.
Will the Speedplay Power pedals work with my existing bike computer and training apps?
The Speedplay Power pedals offer dual-band ANT+ and Bluetooth for seamless connectivity with virtually any device. They can link to three Bluetooth devices at once while broadcasting to unlimited ANT+ devices, ensuring maximum flexibility. This makes them compatible with popular bike computers like Wahoo ELEMNT, as well as smartphones, tablets, and leading training apps such as Zwift and TrainerRoad. While they integrate flawlessly within the Wahoo ecosystem, they’re not limited to Wahoo products, giving riders the freedom to train with their preferred setup. With broad compatibility and reliable connections, these pedals make training simple, versatile, and hassle-free.
Are the Speedplay Power pedals difficult to clip into compared to other pedal systems?
The Speedplay Power pedals feature dual-sided entry, letting you clip in from either side without flipping the pedal. This design removes the hassle of single-sided systems, making engagement quick and effortless—perfect for fast starts, stoplight accelerations, or race situations. Beyond convenience, the dual-sided entry improves efficiency by positioning your foot closer to the spindle, maximizing power transfer with every pedal stroke. The result is smoother engagement, greater confidence, and enhanced performance. With their intuitive design and optimized biomechanics, Speedplay Power pedals deliver both ease of use and professional-level efficiency for every ride.
How often will I need to charge the Speedplay Power pedals, and what about maintenance?
The Speedplay Power pedals deliver up to 75 hours of ride time from a rechargeable lithium battery, so most cyclists only need to charge every few weeks. Designed for longevity, they feature stainless steel construction and a triple-sealed bearing system that minimizes maintenance while ensuring lasting durability. With built-in temperature compensation, the pedals maintain precise accuracy across all weather conditions, eliminating the need for frequent recalibration. This combination of long battery life, rugged design, and consistent performance makes the Speedplay Power pedals a reliable, low-maintenance choice for cyclists who want to focus on training, not equipment upkeep.
What specific training insights can I get from the Speedplay Power pedals?
The Speedplay Power pedals feature a left-sided sensor that delivers reliable cycling metrics, including total power and cadence. With cadence tracked by an internal gyroscope, riders gain detailed insights into pedaling dynamics for identifying optimal power and efficiency zones. This sports-science approach goes beyond simple watt measurement, providing a deeper understanding of technique. By combining precision data with actionable insights, the Speedplay Power pedals help cyclists train smarter and improve performance more effectively.
