TICKR FIT Replacement Straps
£11.99
Our forearm heart rate strap is compatible with the Wahoo TICKR FIT optical heart rate monitor. This adjustable band is gives you a reliable and secure fit to withstand your toughest workouts including running, cycling, fitness classes and more. Simply remove the pod and it is easily hand washable.
  • Contains a small and large strap
  • Hand wash only
  • Not compatible with chest straps
This item cannot be returned or exchanged unless defective. Heart rate sensor pod not included.
