- Home
- All Products
- Indoor Cycling
- Smart Bikes
The Ultimate Indoor Bike
Ride Real. Ride Ready.
Bring Your Ride Inside
KICKR BIKE Pro
£3,499.99
KICKR BIKE Shift
£1,799.99Your KICKR Ride Companion
FAQ
The KICKR BIKE PRO and KICKR BIKE SHIFT can be adjusted at 5 touch points across the bike. The Wahoo app walks you through fit setup based off external bike fit numbers or through inputting your height and inseam measurements. It's easily adjustable for riders between 5' and 6'6" tall.
The KICKR BIKE PRO and KICKR BIKE SHIFT stock road drop handlebars are compatible with most aftermarket clip-on/bolt-on aerobars, offering a 31.8 mm diameter clamping surface that is 100 mm wide overall. The BIKE's stock stem clamp is 40 mm wide. There is an available clamping surface from 20-50mm from the handlebar's center point on both sides.
